Message 11 of 23
Re: Ethernet Cable putting me on different network
@TomJ_Taylorwrote:
No I don't, I'm connected via 20m ethernet cable straight from my PC into the router
Tracert?
Message 12 of 23
What's that?
Message 13 of 23
Message 14 of 23
Seems to also be causing issues with my xbox one! It seems that any Ethernet connection to the BT hub just puts me onto a sky network, meaning I am unable to play online or download any games because the connection is awful
Message 15 of 23
Tracert?
Message 16 of 23
What do you get on your phone if you dial 150, as you may have a crossed line?
Anonymous
Not applicable
Message 17 of 23
Did you try my suggestion in message 5?
Message 18 of 23
If you're plugged into a BT hub connected to a BT network, and there's no other network connections from your devices (for example wifi to the sky router), then you are connected to BT.
If not, one of these:
You're connected to sky via wifi "ipconfig /all" in a command prompt will help show that.
You're not connected to what you think you are - check the cables.
You're not on the Sky network - "tracert www.bbc.co.uk" in a command prompt will prove that.
You're using powerline connectors and connecting to the wrong endpoint, maybe even a neighbour
Your BT hub is connected to Sky broadband.
Message 19 of 23
A BT hub can't authenticate on SKY broadband.
Anonymous
Not applicable
Message 20 of 23
@ch Not at all likely.
More like the Sky network name has been remembered by the O.S.
All that's required is a simple painless network reset but the OP seems resistant for some reason.
