Message 1 of 16
Eurosport not working
Hi,
I have the Big Sport package with HD.
 The EPG shows the Eurosport channels, but when I try and access them it tells me I need the Big Sport package. I'm somewhat confused.
What needs to happen for them to work?
Tags (4)
15 REPLIES 15
Message 2 of 16
Re: Eurosport not working
Morning @ZXClaire , your issue is sorted now, sorry for the poor experience
Message 3 of 16
<Pantomime>
Oh no it isn't!
Message 4 of 16
It should be, what do you see when you go to Eurosport?
Message 5 of 16
See picture.
I've even powercycled the TV box.
Message 6 of 16
And did you press OK?
If you press OK it sets the channel up to work (when you have the subscription)
Message 7 of 16
Ahhh, it was doing that before then failing, so I didn't bother pushing OK this time!
So, yes, it is now working. Many thanks
Claire
Message 8 of 16
Hi,
I have this same problem. Changed to the Big Sport package a couple of weeks ago, and cannot get Eurosport. I have the same message that I need to set up the channel, and clicking 'ok' takes me to the screen about switching package.
Thanks for your help.
James
Message 9 of 16
Hello @viscount sorry for the inconvenience, it should be working now!
Message 10 of 16
Thanks for the quick reply @DarrenW .
It isn't, unfortunately. Still the same message after clicking ok. The only thing available then is 'close'.  Have reset the box, is there anything else I should do?
Thanks.
