Message 1 of 10
Extremely slow upload speed
Hi
About a week ago I started experiencing issues while working from home so did a basic speed test and discovered that my usual 18mb upload speed was now around 0.6mb.  I contacted support and was fobbed off with the usual statement around no guaranteed upload speeds.  I did highlight that I wasn't looking for a guarantee but just an improvement.  I also mentioned that BT had been doing work in my cabinet about the same time my upload speed became a problem.
Here is the BT wholesale report
Performance Test Results Report
Basic Performance Test -
Time Stamp Latency Download Upload
Thursday 2 September 2021 | 10:53:27 16 Ms 69.53 Mbps 0 Mbps
Advanced Performance Test -
Download Test
Download speed achieved during the test was 69.53 Mbps
For your connection, the acceptable range of speeds is 40-71.62 Mbps
Your DSL Connection Rate: 0 Mbps(DOWN-STREAM),0 Mbps(UP-STREAM)
For your connection, the maximum achievable download speed is 71.62 Mbps
IP Profile for your line is 71.62 Mbps
Upload Test
Upload speed achieved during the test was 0 Mbps
For your connection, the maximum achievable upload speed is 20 Mbps
IP Profile for your line is 20 Mbps
Summary Advanced Performance Test -
Result Message
We were unable to identify any performance problem with your service at this time.It is possible that any
problems you have experienced may have been caused by traffic congestion or by a server responding
slowly. Please visit the Speed Test Guidance if you are unable to understand the test results
If anyone from BT reads this forum I would appreciate some basic support for the service I pay for
9 REPLIES 9
Message 2 of 10
Re: Extremely slow upload speed
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 10
I don't use the home hub, what stats are you looking for?
Message 4 of 10
should have also said the quiet line test is ok
Message 5 of 10
According to dslchecker you had an 74/19mb connection in July
Looking for connection stats including noise margin and internet connection time
Run btspeedtester and post results
https://speedtest.btwholesale.com/
Message 6 of 10
The wholesale speed test results were in the original post, but I've just run it again and these are the results
Thursday 2 September 2021 | 17:24:5 12 Ms 68.63 Mbps 0.15 Mbps
Download Test
Download speed achieved during the test was 68.63 Mbps
Upload Test
Upload speed achieved during the test was 0.15 Mbps
Result Message
Message 7 of 10
Still waiting for connection stats.
Message 8 of 10
like i said in the previous post, i don't use the home hub so what stats are you looking for?
Message 9 of 10
I have already posted sort  of stats information needed
Message 10 of 10
Hi @Conrady,
If you connect to your router's management page, you should be able to find your connection information.
This will include things like your sync speed for download and upload, noise margin and connection time and a few other stats.
If you could include that information it will give us a good indication of how the connection is performing and what could be causing the lack of upload speed.
Thanks,
Paddy
