Message 1 of 6
Extremely slow Upload speed, but Download speed is fine - please help
Hi there, we currently have BT's Fibre 2 where we can 70MB Download and 20MB Upload. However, for the past 2/3 weeks we just can't get more that around 0.5MB on the Upload. Download is fine.
I've check on Ookla and Google Speed Test and both have similar results.
I've contacted BT who checked the hub remotely and said that we're getting the 70MB Download and 20MB Upload to the router, however that is not coming through on the PC which is connected via a Netgear switcher to the hub.
We've contacted Dell support (who were brilliant) and did a thorough check of the PC and again, found nothing untoward.
PC is only around 8 months old, but when trying the same test on our Mac, we get the same result so we know it's not the PC.
Any help to solve the mystery would be really helpful.
Here's the technical log from the BT Hub:
Product code:Hub
Serial number:+091300+2022017206
Firmware version:v0.38.00.10147-BT
Firmware updated:Sun Feb 26 13:09:35 2023
Board version:R01
GUI version:1.77 20_05_2022
DSL uptime:5 days,05 Hours51 Mins31 Secs
Data rate:19.999 Mbps / 79.999 Mbps
Maximum data rate:36.196 Mbps / 103.432 Mbps
Full Fibre (FTTP) Mode:On
Noise margin:23.8 / 11.7
Line attenuation:7.7 / 10.4
Signal attenuation:7.7 / 11.5
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:27.6 GB Uploaded / 53.3 GB Downloaded
Broadband username:[email protected]
Public Wi-fi status:Activated
2.4 GHz wireless network name:BT-78AHXS
2.4 GHz wireless channel:Smart (Channel 11)
5 GHz wireless network name:BT-78AHXS
5 GHz wireless channel:Smart (Channel 36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:18:82:8C:54:3D:8D
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
TIA,
Jem.
5 REPLIES 5
Message 2 of 6
Re: Extremely slow Upload speed, but Download speed is fine - please help
Hi @Jem_Patel,
Thank you for posting and welcome to the Community.
I'm sorry if you're experiencing issues with your upload speed. Have you tried testing the upload speeds with the Netgear switch removed?
Thanks,
Paddy
Message 3 of 6
Hi Paddy,
Thanks for your response, yes I put a (different) ethernet cable directly from the hub to the PC and get the same reading.
Message 4 of 6
if problem existed for 2/3 weeks then something is uploading as 27gb uploaded in last 5 days hub connected
Message 5 of 6
Yes, we do a lot of HD video content uploads to WeTransfer, but right now nothing is using it.
Message 6 of 6
Hi @Jem_Patel and thanks for posting.
I'll be happy to take a look at this for you. Please check your inbox for my message and drop me a reply with the details.
Cheers
David
