Message 11 of 15
Re: FFTP Internal House Cables can it use Cat6 instead of Optical?
Ok so no access to the signal to use convertors or anything like that. Its maybe something that will evolve as a lot of houses now are just wired for data with Cat6 or higher, some way to tap into that without having to run new cabling seems reasonable.
Thanks for the info, I will enjoy my Fibre to Cabinet implementation for the foreseeable.
Message 12 of 15
TBH that didn't really contribute to the conversation, but thanks for taking the time.
Tags (1)
Message 13 of 15
Most new build houses are wired for data from the site of the ONT.
Message 14 of 15
Simple solution as you have CAT 6 for the master socket.
Disconnect phone line in roof space.
Have ONT sited near to the master socket.
Change master socket faceplate for RJ45 faceplate.
In roof space fit RJ45 to CAT6 phoneline.
Site hub in roof space cconnect to internal sockets.
Connect CAT6 phoneline to WAN port.
Connect ONT to RJ45 mastersocket with flylead.
Job done.
Message 15 of 15
New builds yes but this one is 120 years old...
