Message 1 of 5
FTTC DLM Reset
I have been having intermittent issues with my FTTC connection dropping a couple of times a day for a few months now.  To cut a long story short, couple of weeks ago I removed all of the old internal phone wiring and moved my HH6 next to the master socket.  I've run some Cat6 cabling around the house to get connectivity where I need it.
I was getting speeds of around 35/10 down/up before the changes, and would struggle to achieve more than a few hours DSL uptime.
Since the changes, the DSL has been solid, my upstream increased immediately to 15Mbps and after a few days the downstream increased to 40Mbps.  All good.
The max data rate is now shown as just over 50Mbps and at 40Mbps the noise margin is a steady 8.9db, so I think I should be able to get another few Mbps on the downstream.
How do I get DLM reset on the line please?
Firmware version:
SG4B1000E020
Firmware updated:
31-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
5 Days, 9 Hours 15 Minutes 19 Seconds
Data rate:
15.98 Mbps / 40.00 Mbps
Maximum data rate:
15964 / 50528
Noise margin:
6.1 dB / 8.9 dB
Line attenuation:
37.4 dB
Signal attenuation:
26.6 dB / 37.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
4 REPLIES 4
Message 2 of 5
Re: FTTC DLM Reset
What product are you on ‘BT Essentials’ is 40Mb download, or are you on a faster package ?
Message 3 of 5
Re: FTTC DLM Reset
connection time is only 5 days and it can take a few weeks for the DLM to automatically increase your speed and reduce noise margin after line problems so just a matter of waiting for auto process
Message 4 of 5
Re: FTTC DLM Reset
@iniltous  The OP wouldn't have 15Mb upstream speed on an essentials package.
@blueboy2001  Unlike ADSL your ISP cannot reset DLM. As long as your connection is now stable and remains that way the DLM should relent automatically.
Message 5 of 5
Re: FTTC DLM Reset
I'm on BT Fibre with Halo 1 which I think is a 80/20 FTTC product (line permitting of course)
