Message 1 of 2
FTTP Fibre 100- Slow Wifi
Hi, all,
Looking for some advice. FTTP installed yesterday, Smart Hub 2 with WAN, arrived today, all good 149mbps on ethernet speed test, but WiFi varies between 100 and 111, is there anything I need to change on router to get it up closer to 150. Thanks
1 REPLY 1
Message 2 of 2
Re: FTTP Fibre 100- Slow Wifi
Hi @mty welcome back to the community and thanks for posting.  Wifi can be impacted by many factors outside of our control such as the number of walls and building material of your home, other wifi networks can also impact on the performance if they are operating on the same channel.
There are a few checks you can do to make the most out of your wifi and I'd recommend checking out this link for more info. Improve your wifi
Neil
