Message 11 of 14
Re: FTTP Install
They can’t pay their mortgage with cake.
Message 12 of 14
Re: FTTP Install
Hi, sorry one last question.
The EZ bend cable they use, is this pre terminated? So any holes etc they drill will need to be the size of the plug on the end not the width of the cable? Or do they terminate once it’s through the wall?
Many thanks
Message 13 of 14
Re: FTTP Install
The Ezibend cable has a connector at one end only, so would be fed from inside out, the hole in the wall only needs to accommodate the width of the cable not the plug, externally the cable is cut to the appropriate length and spliced in the CSP
Message 14 of 14
Re: FTTP Install
Thank you so much for that information.
