Message 1 of 4
FTTP Upload
Is there any plans in the near future for BT to upgrade the upload speed on the top fibre package? I know they can achieve much higher than 110 or even the 220 the wholesale checker says because for the first day my fibre was installed i had 1000 both ways so i dont understand why the option to pay more for more upload isnt there
3 REPLIES 3
Message 2 of 4
Re: FTTP Upload
I don't know where you got the 1000 upload figure from on the first day as it is impossible on the Openreach FTTP network as it doesn't support a syncronous connection.
There is nothing planeed in the near future.
Message 3 of 4
Re: FTTP Upload
For 24 hours after activation i had these speeds then the next morning it went off for 1 hour and came back on with only 115 upload so yes it is possible
Message 4 of 4
Re: FTTP Upload
It won't be possible but the fibre connection is shared up to 32 users at around 1.2gigabits
