Message 1 of 4
FTTP drill hole
Hello!
My partner and I have today had FTTP installed. The single drill hole through the outside wall which has the cable running through has not been filled inside or out.
Should this have been filled? Is it okay to leave it this way?
  • Any help appreciated
Cheers
Shane
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: FTTP drill hole
@Starwire  should be able to advise in this when he drops in later.
Message 3 of 4
Re: FTTP drill hole
I believe some installers put a little sealant round the hole if they have any.
Mine was left without at my request as I'd rather tidy the hole up myself.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 4
Re: FTTP drill hole
They’re supposed to use an Internal Lead In kit to cover the hole inside.
You can use an External Lead In kit on the outside as well if you want but I don’t, I just fill it with silicone.
