Message 11 of 15
Re: Fault Repaired, Speed hasn't increased
Its disconnected while I was out, I take it I'll need to contact BT to get an engineer to look into it?
Message 12 of 15
Your connection speed is well within your expected range from dslchecker so looks ok
you just need to leave connected and after 10/14days stable connection DLM will hopefully activate G.INP which will give a small boost to connection speed
cant see BT doing anything as speed is in expected range
Message 13 of 15
ok, thanks for your help.  I'll just go down the uso route as its under 10meg.
Message 14 of 15
remember the uso also includes speed using your mobile connection
Message 15 of 15
Unfortunately I have no mobile coverage so I don't think that'll be a factor.  I'll speak to them & see what they say.
