Message 1 of 15
Fibre 2 slower than Fibre 1
Hi,
I upgraded on the 29th to Fibre 2 from Fibre 1.
My speed has gone down to 38mb/s, whereas I got a constant 48mb/s when on Fibre 1.  My upload speed has increased from 9mb/s to 14mb/s.
I use a Draytek Vigor 2762 and don't really want to install the BT Hub to do tests.
Anyone suggest anything?
14 REPLIES 14
Message 2 of 15
Re: Fibre 2 slower than Fibre 1
if you could only get 48mb connection on fibre 1 then I can't see why you would upgrade to fibre 2 as your down wont get any faster unless it was just faster up speed you wanted
which exchange and cab are you on?
Message 3 of 15
OK good to know, thanks.
My check on the broadband availability site said I should get a low of 65mbs down. Not sure where you're meant to find out otherwise.
Harrow cabinet 89.
My handback value is 57mbs, so presumably I can just cancel this 'upgrade' with no issue?
How would I do that in these testing times?
Message 4 of 15
can you post some stats from your router
can you also post dslchecker results using phone number  https://www.broadbandchecker.btwholesale.com/#/ADSL
Message 5 of 15
This OK?
Message 6 of 15
can you check your line for noise  dial 17070 option 2  should be silent and best with corded phone
Have you tried using the test socket with a filter to see if that improves your connection and attainable speeds
Message 7 of 15
Quiet line sounded...quiet..don't have a corded phone, but I couldn't hear anything.
I have an Openreach MK1 socket - do I need to open it up for this test?
My attainable speed was 49000 ish when on Fibre 1 up until this Friday when Fibre 2 was put in place.
Message 8 of 15
test socket shown here  you need to remove the middle section first shown by yellow arrow
was quiet line test done with cordless phone?
Message 9 of 15
Yes, cordless phone only available.
So I need a filter as well if using this socket?
Thanks for the suggestions, this may take a little longer to organise.
Message 10 of 15
yes the rj11 cable from hub will not fit
