Message 1 of 4
Fibre 900 Upload Speeds
I got my Fibre 900 installed around March this year and my upload speeds were around 50Mbps at the time, I recently have been doing speed tests to see if it's still the same only to notice that my upload speeds seem to be capped around 10Mbps. Is there any fix for this?
3 REPLIES 3
Message 2 of 4
Re: Fibre 900 Upload Speeds
Hi @kayfour,
Thank you for posting and welcome to the Community. I'm sorry if you're not happy with the upload speed of your connection.
How are you testing your connection, are you using a wired or wireless connection? Please could you run a speed test and post back the results?
Thanks,
Paddy
Message 3 of 4
I've tried a couple different websites that I could find test my speed and they all show the same result. I'm using a wired connection from the hub to my PC. They all seem to float around the 450Mbps download and stuck on 10Mbps upload
Message 4 of 4
Thanks for posting the test results @kayfour .
I'll be happy to take a look at this for you. I'll drop you a private message now so you can get in touch.
Cheers
David
