Message 1 of 7
Fibre 900 upload speed capped?
Hi,
Just had the FTTP 900 line installed this morning. Getting a steady 924 down. But why Is the upload capped to 51? should be more than that? Or Is it the SH2 firmware?
6 REPLIES 6
Message 2 of 7
Re: Fibre 900 upload speed capped?
Hi @SoggyTissue and welcome to our community.
Sorry your upload speed isn't as expected. As you've just been connected you need to leave it a few days as it can sort itself out. If you don't see any change by the weekend pop back and we'll take a look for you.
Cheers
David
Message 3 of 7
Thanks for the quick reply. As I can see in other threads this seems a common thing to happen.
I Will get back to you If there Is no change, but It definitely looks like it's locked to 51 you can see it trying to go higher!
Message 4 of 7
SH2 has a firmware issue where your upload is capped at 51 mb/s.
Using an aftermarket router would fix the issue.
I run my fibre 900 through an ASUS RT-AC86U and receive the full 110 upload.
Message 5 of 7
Well, as of this morning I'm now getting exactly 924/111 so fingers crossed the line will stay like that!
The SH2 must have done a firmware fix.
Message 6 of 7
Hopefully!
Message 7 of 7
@SoggyTissueThat's why @DavidM  asked you to wait a couple of days to give the hub chance to update the firmware.
