Message 1 of 10
Fibre Upgrade no change
So, we received our switchover date from BT and a nice new shiny Smart Hub 2, the new hub is installed and the switchover date has been and gone however we're getting download speeds of 10mbs at best, not what I'd expect from fibre
9 REPLIES 9
Message 2 of 10
Re: Fibre Upgrade no change
What speed were you guaranteed  in the email you were sent?
If you put your phone number in the checker https://www.broadbandchecker.btwholesale.com/#/ADSL and post a screenshot of the results we can see what speed you should expect. Remember to edit out your phone number before posting.
Message 3 of 10
Message 4 of 10
post stats  HH6/SH2 then advanced settings then technical log information .
Message 5 of 10
Thanks,
It is strange, if there's no difference then there really was no point in BT switching us over, I've looked at the emails regarding the switchover and there's no mention of speed other than 'BT fibre is up to 3x faster than standard uk fibre'
Message 6 of 10
Not sure I know what "post stats  HH6/SH2 then advanced settings then technical log information" means, can't find anywhere to show HH6/SH2 stats?
Message 7 of 10
if you go to hub manager then advanced settings then technical log information (not logs) you will see the required stats
Message 8 of 10
Product code:
Smart Hub 2
Serial number:
+091301+1949048577
Firmware version:
v0.17.01.12312-BT
Firmware updated:
Mon Jul 13 01:02:09 2020
Board version:
R01
GUI version:
1.56 15_02_2019
DSL uptime:
1 days,07 Hours08 Mins24 Secs
Data rate:
1.227 Mbps / 12.507 Mbps
Maximum data rate:
1.228 Mbps / 12.568 Mbps
Noise margin:
5.9 / 3.1
Line attenuation:
15.1 / 34.0
Signal attenuation:
15.5 / 42.1
VPI/VCI:
0/38
Modulation:
G.992.5(ADSL2+)
Latency type:
Fast
Upstream error control:
Off
Downstream error control:
Off
Data sent / received:
1.2 GB Uploaded / 12.9 GB Downloaded
Broadband username:
[email protected]
BT Wi-fi:
Activated
2.4 GHz wireless network name:
Smart Hub 2
2.4 GHz wireless channel:
Smart (Channel1)
5 GHz wireless network name:
Smart Hub 2
5 GHz wireless channel:
Smart (Channel36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
0C:8E:29:A0:E9:C0
Software variant:
Boot loader:
0.1.7-BT (Thu Nov 30 09:45:22 2017)
Message 9 of 10
You haven't been switched to fibre yet, you are still on ADSL.
Message 10 of 10
Thanks, that's strange, they said the switch date was 10th July, that would explain it
