Message 1 of 5
Fibre - WAN cable length
 Is it ok to run a (roughly) 6m WAN cable from the white fibre box, to the wifi router?
Do i need a specific cable?
The router will be more central in the house, in this location, and i can also plug my TV and xbox in from there...
Thanks!
4 REPLIES 4
Message 2 of 5
Re: Fibre - WAN cable length
You can run Ethernet cable Cat 5E or above up to 100 meters and it will work.
Message 3 of 5
Ahh cool. Well thats good to know. Without  a loss or speed? Thanks!
Message 4 of 5
Cat 5e is good for 1 Gbps up to 100 metres. So you won’t get speed loss over 6 metres, even if you’re on the Fibre 900 package.
Message 5 of 5
Yes, without loss.
