Message 11 of 14
Re: Fibre halo2 speeds just dropped by 2/3
Thank you so much
Message 12 of 14
The reason the hub is telling you that you can only get 16Mb is because that is all you can get with the condition of the line. You are connected with one wire instead of two.
Once the phone line is restored your speed will go back again.
Happy to see I was right with the cause.
Message 13 of 14
You were spot on. Thank you
Message 14 of 14
Glad I was able to help.
