Message 1 of 13
Fibre speed lower than what my package states
Hi
How do i get my internet speeds increased?
Our speeds are 45Mb but our package says we should have 55-73Mb
12 REPLIES 12
Message 2 of 13
Re: Fibre speed lower than what my package states
It would be better if you gave us a little more info.
Can you post your hub connection stats? Login to the hub and go to advanced strrins/technical log/information for HH6 and super hub or if HH5 trouble shooting/helpdesk.
Is there any noise on your line?  17070 option 2, best with corded phone. If any noise report a line fault.
Message 3 of 13
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 4 of 13
Below are the details from the router
Data rate 19.999 Mbps / 49Mbps
Maximum Data Rate 23.695Mbps / 61.791Mbps
Noise Margin 8.2 / 9.3
Line Attenuation 7.2 / 13.9
Signal Attenuation 7.2 / 15.3
Message 5 of 13
Telephone Number xxxxxxxxxxxx on Exchange HONINGTON is served by Cabinet 8
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
VDSL Range B (Impacted)
8062.8201956.8AvailableAvailable--
8060.3201955AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+ADSL MaxWBC Fixed RateFixed Rate
Up to 2--1 to 3.5AvailableAvailableYes
Up to 1.5--1 to 2.5AvailableAvailable--
0.5----AvailableAvailableYes
0.5----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
49
20
2020-07-06
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
29-07-2020
Message 6 of 13
The full stats would have been better
connection time is missing
what about quiet line test?
are you conencted to master socket?  Have you tried using the test socket with a filter to see if any improvement
hvae you been having problems with your connection dropping? Often? Have you been resetting the hub to try and improve your connection speed?
Message 7 of 13
Product nameBT Smart Hub 2
Serial number1850111112
Fireware versionv0.17.01.12312-BT (Mon May 11 18:49:53 2020)
Board versionR01
GUI version1.56 15_02_2019
DSL uptime1 days 3 Hours 45 Mins 19 Secs
Data rate20.0 Mbps / 49.0 Mbps
Maximum Data rate22.9 Mbps / 59.2 Mbps
Noise margin7.4/8.7
Line attenuation7.2/14.0
Signal attenuation7.2/15.4
VLAN id101
Upstream error controlOff
Downstream error controlOff
Data sent / received430.7 MB Uploaded / 2.1 GB Downloaded
Broadband username[email protected]
BT Wi-FiActive
2.4 GHz wireless network nameBT-GSA2PN
2.4 GHz wireless channelChannel: 11
5 GHz wireless network nameBT-GSA2PN
5 GHz wireless channelChannel: 48
Wireless SecurityWPA2 (Recommanded)
Wireless modeMode 1
FirewallOn
MAC address44:FE:3B:D6:DC:BA
Software variant-
Boot loader 0.1.7-BT (Thu Nov 30 09:45:22 2017)
The quiet line test sounds good with no hissing, crackling or pops.
We are connected to the master socket
Hope this helps
Message 8 of 13
Have you tried using the test socket with a filter?
connection time is only 1 day is that due to hub dropping connection or manual reset?
enter your phone number and post results.
Message 9 of 13
Featured Products
Downstream Handback
Left in Jumper
Threshold(Mbps)
High
Low
High
Low
80
62.8
20
19
56.8
Available
Available
80
60.3
20
19
55
Available
Available
Featured Products
Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Left in Jumper
WBC ADSL 2+
Up to 2
1 to 3.5
Available
Available
ADSL Max
Up to 1.5
1 to 2.5
Available
Available
WBC Fixed Rate
0.5
Available
Available
Fixed Rate
0.5
Available
Observed Speeds
VDSL
49
20
Observed Date
06/07/2020
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise Environment
Status
Bridge Tap
N
VRI
N
NTE FacePlate
N
Last Test Date
29/07/2020
Message 10 of 13
The hub must have reset itself as I haven't touched it
