Message 81 of 87
Re: Fingers crossed!
Personally I would go with a third party router. I'm sure @busterboy1  would agree as he has.
Why go for a top of the range connection and use a hobbled ISP supplied router? To me it beggars belief.
Meantime post your upload problem in this thread and a mod will get around to you.
https://community.bt.com/t5/BT-Fibre-broadband/BT-Fibre-900-Upgrade-Smart-Hub-2-upload-throttling/td...
Message 82 of 87
My router is on the latest firmware.
The fella in the faults team said it's definitely a software issue, and it needs changes at the back end, as well as to my smarthub firmware.
He said a patch will be uploaded this afternoon, and he will call me when it's all done.
He said the common issue was the Upload being stuck at 50, but a less common issue is the Upload being stuck at 10, which requires a different fix.
Message 83 of 87
So if it is a known issue and they have the fix why isn't a new firmware upadate automatically happening?
Message 84 of 87
Could have been bug  in firmware and they have to re-apply it again, i was mentioned this with enginner at the time to.
Put it this way though, BT customer service have been really good, just wish Virgin media had this service while i was with them back then. (they have been atrocious)
As the title says fingers crossed for you and you get your speeds sorted out hopefully today.
Message 85 of 87
I do agree, BT seem to have really upped their game.
Obviously the foreign call centres being axed has done the trick.
Message 86 of 87
That is a very good question Pippin.  As it stands mine isn't fixed yet, I'm due a call back at 2pm with an update.
Message 87 of 87
BT have fixed my Upload now, but I have no idea what they have done, because the guy called me was unsure himself.
Looking at the router stats, it hasn't had a firmware update.
The speed test was via my phone, on WiFi, with others using it, so it's not a bad connection, but I'm sure if I buy a new router it would improve.
No idea what to buy though!
