Message 1 of 7
Freeview play tv versus BT Youview
Why is my Freeview Play TV picking up freeview channels that my BT Youview box doesn't, using the same aerial?
6 REPLIES 6
Message 2 of 7
Re: Freeview play tv versus BT Youview
It probably has a stronger tuner than the ones in the Youview box.
Message 3 of 7
Does anyone know if the new Pro Box has a better tuner, please?
Message 4 of 7
It has more modern equipment so it should be better
Message 5 of 7
Because you have a marginal Freeview signal.
Message 6 of 7
Thanks both.  Gomez, sorry I am not a technical whizz, what is a marginal signal and is there anything I can do about it?
Message 7 of 7
1) Check the aerial and wiring is all in good condition and that the aerial is accurately pointing at your preferred transmitter;
2) Move to an area with better TV reception.
