Message 11 of 18
Re: Frequent Connection Failure (Line Stats + BT Wholesale check included)
That's just showing your attainable rate. Your actual rate won't improve until DLM releases the banding and that can take several weeks.
Message 12 of 18
I understand. I've currently got 4/1 interleaving applied to the line. When that gets taken off though, things should be good. Wish there was a quicker way to change it but I can't afford to leave the line disconnected for 24hrs and I spoke to BT customer service who didn't seem to know what I was on about ¯\_(ツ)_/¯
Message 13 of 18
Possibly because leaving the line disconnected for 24hrs won't change anything.
Message 14 of 18
Exactly
Message 15 of 18
Oh, I meant I'd spoken to see if I could get the DLM reset to zero interleaving.
As for removing the modem 24hrs, a couple of other community posts here seemed to suggest that was an alternative to get them to clear whatever had been applied to the line
Message 16 of 18
No idea where you got that idea from. DLM will require several weeks of line stability before it will do anything.
Message 17 of 18
Fat chance of stability with noise on the line.
Message 18 of 18
Again, it's not much. I was being picky. Checked my modem stats now I've made the change and there have been zero error seconds / resyncs in the past 2 days. As I understand it, from Kitz forums, those are the metrics DLM uses.
I'd say any hardware problems have been resolved now. It's just a waiting game
