Message 1 of 3
Full Fibre upgrade
Hi
If I accept BT offer to upgrade from copper/fibre to Full Fibre can I...
1. keep copper landline for existing and still required telephone ?
2. keep existing Openreach modem & BT hub ? And...
3. still use above devices for broadband wifi as now in ADDITION to new Full Fibre 100 with BT Halo 1 broadband wifi
2 REPLIES 2
Message 2 of 3
Re: Full Fibre upgrade
@DYLAN2020 wrote:
Hi
Possibly. I think you will get a choice to keep copper line or use digital voice via fibre.
The modem is superfluous but you can keep using the BT hub as if you are using it with a modem it will have a WAN port.
Only if you want to pay for 2 broadband circuits.
Message 3 of 3
thank you
