Message 1 of 16
Full fibre 900 slow upload after f/w update
My smart hub 2 had a firmware update to  v0.21.03.07094-BT  a few days ago and since then my upload speed is between 40/50 Mbps whereas before the update I was getting a solid 120 Mbps. Download speeds are fine and always have been.Can anyone help .
Phill
15 REPLIES 15
Message 2 of 16
Re: Full fibre 900 slow upload after f/w update
Hi @Phillm sorry that this has happened again and I only got it fixed for you a few days ago. I've still got your details to hand so I have requested the upload cap to be lifted again for you. I'll keep you updated.
Cheers
JohnC2
Message 3 of 16
Cheers JohnC2
Message 4 of 16
@JohnC2  Thank you, back up to 120 now 😁. Keep up the good work guys 👍
Message 5 of 16
Good afternoon.
Since Fibre900 has been installed upload speed is only 50mb. As previously mentioned by users nothing really can be done..
Message 6 of 16
Hi @Phillm, thanks for the update the team lifted the cap again when I was away at lunch and happy your upload fixed again 🙂
@Piotrch sorry your upload is capped at 50mb. I've sent you a Private Message with details on how to contact the Mod team and we'll be happy to help you get this fixed.
Cheers
John
Message 7 of 16
This is now happening to me,
fiber went live Monday, can’t get above 500 on a direct connection for download or above 50 for uploads
Message 8 of 16
Hi @Aaronw123 and thanks for posting.
Sorry you're connection isn't as fast as it should be. I'll be happy to help. I'll drop you a private message so you can get in touch.
Cheers
David
Message 9 of 16
I’ve sent you a message John I’m having issues with my upload on fibre900 I’m thinking it’s due to a cap that needs lifting please help it’s driving me nuts 😂
Message 10 of 16
Hi @JohnC2 It's happened again, upload speeds are now capped at 30 Mbps
Regards
Phill
