Message 11 of 14
Re: Full fibre 900 speed issue
done and done.
still the same
Message 12 of 14
Why do you think because you have a pricey router it's better? YOU never provided any other information about how many devices you're trying at the same time. The actual spec of the machine running.  Other programs running in the background? Windows? Anything that could be using resources to prevent you from hitting max speed?
Message 13 of 14
Ok FAST.com is reporting back 890/110.  So I would say it’s pretty much there
Message 14 of 14
Firstly the BT router isn’t great ( which we all know )
the spec of my laptop isn’t bad .
i7 6700hq
Gtx1060
2tb M.2 drive
32gb ram
the only programs running in the back other than the standard suit of windows , would be my stealseries software , steam client ,  but I have very little installed
no other devices connected at the time of testing, as my fibre has only just been installed 48hrs ago, and most my devices are still running from my virgin internet
