Message 1 of 6
G.Fast
Openreach have been installing G.Fast extension cabinets on all the cabinets in my town, is there a way to find out when it will be available to purchase in my location? It is not currently showing on the broadband checker website. It must be about 6 weeks since they installed it on my cabinet.
5 REPLIES 5
Message 2 of 6
Re: G.Fast
Just keep checking on the dslchecker until you see available then order
Message 3 of 6
Re: G.Fast
Nope, all you can do is keep checking the checker. It could be months before it becomes available.
Message 4 of 6
Re: G.Fast
Ok, thanks!!!
Message 5 of 6
Re: G.Fast
The upgrade of G.Fast has been suspended until April 2021 as Openreach are concentrating on FTTP Upgrades instead.
https://www.ispreview.co.uk/index.php/2020/06/openreach-confirm-g-fast-broadband-rollout-paused-unti...
Message 6 of 6
Re: G.Fast
They won't be G.Fast pods.
The G.Fast rollout has been paused.
They will be VDSL Sidepods.
Basically they've managed to fit a VDSL DSLAM (what's in the fibre cabinets) in to the same pods they were using for G.Fast.
It's how they are increasing capacity now, and saves them installing a 2nd (or even 3rd) fibre cabinet.
They contain a Huawei MA5818 DSLAM with VDSL2 line cards.
If you lookup you cabinet on codelook it might tell you they have added a VDSL Sidepod to your cabinet.
https://www.telecom-tariffs.co.uk/codelook.htm
