Message 11 of 12
Re: Gigabit speeds
Can you not just temporarily disconnect another piece of kit and try the laptop on the end of that cable?
Message 12 of 12
Re: Gigabit speeds
@gingerangles wrote:
I can only think this must be it... although I've continuity tested the cable and that says it's ok.
Perhaps I should try redoing the plugs?
Good plan
