Message 11 of 15
Re: HH5 blue light no internet
Sorry - see below. I can get online for now but need to be sure it's not going to happen again as it's been like this for a while.
Message 12 of 15
Thanks. Will try to split it now - I see an 'unknown' currently connected to the 5Ghz - what would that likely be??
Message 13 of 15
Just googled : assume that's the skybox but not sure why that would need wifi connection?
Message 14 of 15
Don't worry about that. It's not a problem.
Message 15 of 15
Ok so have done both as you suggested. It's still connected now. Do you know if there's anything else I can do/check? Don't want it dropping again when I'm not here to help.
