Message 1 of 2
Halo
When I upgrade to Halo 1, will I receive a new router?
Thanks,
Steve
1 REPLY 1
Message 2 of 2
Re: Halo
It depends what you upgrading from. If you are on ADSL (Normal) broadband then yes you will get a BT Smarthub.
If you are already on a fibre broadband package the answer is no if you have a BT Homehub 5 or above.
