Message 1 of 6
broadband package
 currently have the fibre 1 package to match the price as bt mucked up my previous order so they gave me the cheaper package. when i look at this deal on the bt page the download speed is at 50mbps, however, when i go on 'your speeds explained' it says it is 24-36mbps. I contacted them about this and they said that the 50mbps speed itsnt available at my household but when i run the check if its available at my household on their website it says it is. anything i can do? feel as if they're scamming me out of my speeds so i pay more.
5 REPLIES 5
Message 2 of 6
Re: broadband package
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 6
where do i find the router stats?
Message 4 of 6
there is no noise on my line at all.  my router stats and availability test is posted below:
stats:
Product code:Smart Hub 2
Serial number:+091298+1950008590
Firmware version:v0.17.01.12301-BT
Firmware updated:Tue Jun 2 19:55:20 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,17 Hours37 Mins38 Secs
Data rate:5.379 Mbps / 29.109 Mbps
Maximum data rate:5.457 Mbps / 37.777 Mbps
Noise margin:6.2 / 6.1
Line attenuation:8.5 / 24.3
Signal attenuation:6.7 / 28.7
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:2.1 GB Uploaded / 19.3 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-J6AFSK
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:BT-J6AFSK
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017
Message 5 of 6
Your line is not capable of 50Mb speeds. You are currently connected within estimated speeds.
Message 6 of 6
Connection time is only 17hrs is that due to hub dropping connection or manual reset
are you having problems with hub dropping connection
