Message 11 of 28
Re: Halo900 + Audit
Message 12 of 28
Re: Halo900 + Audit
They're the ones telling me it's the cable, from the white box to the hub. Even the WiFi signal is poor, I'm sorry but I'm paying a lot of money for this, so they should at least honour their own claim. Not give me misinformation. I'm documenting everything in writing now.
Message 13 of 28
Re: Halo900 + Audit
@AuditingHalo900wrote:
List it, tell EXACTLY how to do it...
Some manners might not go amiss, remember this is a bt customer to customer forum and all help is free!!
I was under the impression you had already done a pppoe test as in message 4 you said you were getting 200-300meg only when you were asked to do the test???
Follow these instructions after connecting a cat5e cable from your laptop direct into the ont port where you plugged the router :-
  1. Right-click on the network icon on your Windows 10 computer and click on ‘Open Network & Internet settings’.
  2. On the left-hand side, go to the option saying ‘Dial-up’.
  3. Now click on the option that says ‘Set up a new connection’.
  4. In the new windows which appear, click on the option saying ‘Connect to the internet’.
  5. There will be just a single option in most new computers. Click on the option, which says ‘Broadband (PPPoE)’.
  6. Now, in the new window, you should enter the username and the password - [email protected] and password bt or blank your choice.
  7. Click on ‘Remember this password’. You can give your own name to the connection, or leave it with the default name.
  8. After configuring everything in this page, click on ‘Connect’.
  9. If the username and the password were correct you should now be able to connect to the internet. You can even connect and disconnect to and from the internet connection from the taskbar of your Windows 10.
  10. Then carry out a speed test and see what you get.
Message 14 of 28
Re: Halo900 + Audit
Sorry mate, I wasn't trying to be rude, I was trying to be brief, I do apologise in any case. My laptop is a MacBook, not a Windows 10, I could buy a windows 10 laptop or I was looking at buying a Chrome Book, in any case, can't their specialist tech team do this? If not I'll try to buy a windows 10 laptop buy next week now. Can you tell me if a Chrome Book would be ok, or which kind of windows 10 pc I.e. with which ethernet card, as I don't want BT to blame my equipment. I don't mind paying more money but don't want to pay BT extra money.
So can you please give me some MacBook instructions if possible?
Message 15 of 28
Re: Halo900 + Audit
See link
Connect your Mac to the internet using PPPoE - Apple Support
The user name and password are as per the previous post for Windows.
Message 16 of 28
Re: Halo900 + Audit
thanks
Message 17 of 28
Re: Halo900 + Audit
I think I'm doing something wrong this is the error I get:
Message 18 of 28
Re: Halo900 + Audit
The credentials should be in the account name not the service name.
Message 19 of 28
Re: Halo900 + Audit
It's not working saying for a password, and then the same error, can someone explain it, in an idiot-proof way, in case I am doing something wrong.Screenshot 2021-09-09 at 9.32.54 pm.png
Message 20 of 28
Re: Halo900 + Audit
Add BT as the password.
