Message 11 of 18
Re: Help with Digital voice - very few incoming calls can dial in - BT runaround
try dialing 17070 and check number is repeated
Message 12 of 18
@gate23wrote:
will BT sort this out? Do I need to contact SKY?
BT Support chat won't even tell me what fault they found - I'm guessing they are on some script where everything stays very non-committal / vague
BT will sort it out, Sky won't help as you're no longer a customer.
Support will run some tests and raise a fault if all doesn't come back as it should, no BT departments use scripts though.
Message 13 of 18
Hi @gate23
Welcome to the BT Community and thanks for your posts.
I am sorry for the problems your Dad is having receiving calls since moving his service to us.  The fact that outgoing calls are fine does point to a number port problem that the guys have mentioned.
I understand how important it is for your Dad's services to be fully working.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Thanks,
Robbie
Message 14 of 18
thank you, message sent
Message 15 of 18
I have a slightly different problem, but perhaps with the same cause...
It took ages to get my originally BT number working on Digital Voice (after leaving for a new provider for a couple of years, then returning to BT for FTTP). But success now. However, there seems to be erratic operation: from my main mobile, after a voicemail call to DV yesterday, when I didn't leave a message, subsequent calls for the rest of the day automatically cancelled with Number not valid (or similar message). A second mobile phone did get through, and DV could be used for outgoing calls. I rebooted the hub but no change.
This morning, after a single successful main mobile call, further calls have been erratic. The same applies to the second mobile. No obvious faults with the internet, showing at the moment >300MBd.
I'm not yet using DECT, with two conventional phones wired into the hub BT431A socket.
Come on BT: if you can't make the service reliable, you shouldn't offer it!!!
Message 16 of 18
Just noticed the 17070 test call: Ringback is not working...
Message 17 of 18
To be fair, BT help-desk Louise took ownership of the problem, with frequent calls to enquire of the current situation, and update me on progress. It now seems to be sorted - apparently my previous provider hadn't properly released the number (D'Oh?). Thanks.
Message 18 of 18
17070 ‘ring back’ , on PSTN , was a check of the ability of the PSTN line card to supply ring current, DV is a completely different animal, it would be a fair question to ask why ‘ring back’ is an option, but TBH , the entire 17070 ‘menu’ is irrelevant with DV, and IMHO shouldn’t be present on DV service, presumably they figured removing it would simply provoke people to enquire why 17070 wasn’t ‘working’ .
