Message 1 of 5
Home Hub 4
Have just set up my new Hub 4 and received a message from Microsoft that the router is not secure and the wifi network is an older security standard that is being phased out. Advised me to use another network
4 REPLIES 4
Message 2 of 5
Re: Home Hub 4
@vobster1
Are you a new BT Broadband customer?
Message 3 of 5
Re: Home Hub 4
yes
Message 4 of 5
Re: Home Hub 4
@vobster1 wrote:
yes
So you must have standard (ADSL) broadband then.
The HH4 does support WPA2 on 5Ghz, which should be fine, so I would not worry about it.
2.4GHz is just WPA which is an older standard.
http://bt.custhelp.com/app/answers/detail/a_id/10490/~/security-on-the-bt-hub
Message 5 of 5
Re: Home Hub 4
thanks for your help- we do have standard broadband
