Message 1 of 10
Horrible BT speeds for a year now
Hey.
So ive been having horrible issues with BT's internet over the past year or so now! and I honestly dont know what to do!! i get speeds less than 2mb on my download and upload and the wifi keeps going down randomly and up again and its super frustrating, ive been waiting as i wantyed to give BT the benfit of doubt but its just getting frustrating at this point, i want to call an engineer but ive heard storys which make me hesitate and £85 if theres no problem or a problem on my end is ridiculous amount to pay.
No matter where i place my router or such it never gets better. so i really need help here! i'm paying £56 a month for broadband and landline{dont use it but cant remove it :/} the broadbands meant to be 70mb gurantuee so i really am a bit puzzled.
someone please help before i decide to end my contract and go elsewhere i really do want to stay with BT but this is just awful.
any advice is great and sorry for my spelling!
9 REPLIES 9
Message 2 of 10
Re: Horrible BT speeds for a year now
Message 3 of 10
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
A faulty landline is the normal reason for very slow speeds, so you will have to test with a wired phone.
Message 4 of 10
If you enter your phone number here, can you post the results ( remove your number when posting)
https://www.dslchecker.bt.com/
Can you access your router stats and also post them.
Any speed test needs to be done using a wired connection not WiFi , have you used wired or wireless to test ?
The first thing to establish is wether you are getting close to what is predicted for you location, no use complaining if you get ( for example ) 30Mb, on a 55Mb product if 30Mb is all your line can deliver , and if you are way off what’s predicted, what’s been done to remove any potential issues within the home.....are you using a extension socket or the master socket, have you done a quiet line test , dial 17070 from the master socket test port with a (preferably) corded phone take the quiet line test option and listened to see if there is any noise ?
Message 5 of 10
I've turned of smart setup and always have had wireless split.
Message 6 of 10
we don't use a landline haven't for the past few years now. So I can't really test that Sorry!
Message 7 of 10
Can't test phone as we don't have one, I'm using a wired connection straight from the router to also using a powerline adaptor getting around 5mb max on download and 14mb upload last time I tested.
It should be a master socket as that's what BT told us when they set it up. We have a big socket in the dining room that's square and a smaller rectangle shape socket in the living room.
Message 8 of 10
Without a basic cheap. less than £10, wired phone, there is no other way to prove the fault, which sound like a disconnection on one wire of your phone line. A check for dial tone would prove that.
You could also save a possible £85 visit charge, if the fault is within your property.
Message 9 of 10
Mum says we have a wired phone so I'll wait for her to test it out and I'll comment back to you guys! Thanks for the help so far.
Message 10 of 10
So one of you wanted to see this, poor image quality as I had to reduce file size sorry
