Message 1 of 9
Hotspot App does not recognise my password
I can log in to the My BT app so I know that the password is correct (I can also log into MyBT on the web but the BT Wi-fi app will not accept the same password.
I am stumped as to what to try next.
Nick49
8 REPLIES 8
Message 2 of 9
Re: Hotspot App does not recognise my password
If you have changed your password at some point in the past try using the "old" password if you can remember it.
Message 3 of 9
Thanks.  It so happens that I might have sorted the problem.  I might have made a mistake in typing in the password.  I now need to goo out and test it.
N
Message 4 of 9
Can you not test it on your own hub, or do you have a third party router?
Message 5 of 9
I might well be able to test it on my own hub if I delete my password so that my mobile has to use the app.
N
Message 6 of 9
Hm... I did that test and I find that I can't log in to BTWi-fi.
This is so frustrating!
Nick
Message 7 of 9
Hi @Nick49 and welcome to our community.
Thanks for posting about your WiFi issue, sorry you're having problems. Can you take a look at BT WiFi Help  and let me know how you get on?
Cheers
David
Message 8 of 9
Hi, David
Sorry that I have been such a long tie getting back.  All apears to be well now and has been for some time.  The proplem was, IIRC (It was a while ago.) that I was not logging into the app correctly.  I do find the hints from the app a little opaque.
Nick
Message 9 of 9
That's great news @Nick49.
Thanks for getting back to us and telling us how you got it working.
Have a great day,
DanielS
