Message 1 of 3
Having a problem activating Parental Controls
@DavidM can you help me too, please?
I've tried to activate the parental controls in MyBT, says it will be done in two hours, but doesn't. I've also re-boot the router.
Thanks, Henry
2 REPLIES 2
Message 2 of 3
Re: Having a problem activating Parental Controls
Hi @HenryD
Welcome to the BT Community and thanks for your post.  I have moved your post to start your own thread discussion as the thread you had posted on has already been marked as solved.
I am sorry for the problems you're having activating BT Parental Controls using your MyBT.  We can pick this up from here and give you a hand to sort this out.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Message 3 of 3
Hi @HenryD ,
Thanks for letting me know we got this sorted for you.
All the best
David
