Message 1 of 6
How do I request a DSLAM reset!
As above
thanks
5 REPLIES 5
Message 2 of 6
Re: How do I request a DSLAM reset!
Do you mean DLM reset? In general, you can't without a visit from an Openreach engineer who positively clears a fault. Why do you think you need it?
Message 3 of 6
I have posted a few threads about my latency increasing and that if interleaving has been switched on then only a DLM reset can resolve this
it’s worth trying as I’ve exhausted everything else
i will raise it with BT to arrange a visit if necessary
Message 4 of 6
Not a chance. DLM is an automatic process, if it thinks interleaving is required then it will impose interleaving. A reset will do nothing, DLM will just re-instate it.
Message 5 of 6
I thought @Keith_Beddoe answered this in your previous post
Message 6 of 6
Then why was my profile set on Fastpath for several years before 2 months ago?
if what you say is true then I should have been on interleaving?
