Message 1 of 3
How to unblock blocked domain
Hi all,
Been getting loads of scam emails lately saying  last chance to update bt's T&C.....
Since finding out they are junk just now I accidently blocked not just the email but the domain so I cant receive
anymore emails from anyone with @btinternet.com or @btopenworld.com
It has the option to remove particular emails from a blocked list but not a domain.
Does anyone know a way to solve this?
Thanks in advance
2 REPLIES 2
Message 2 of 3
Re: How to unblock blocked domain
You remove a blocked domains in the same way as you remove an email address.
Locate the blocked domain then tick the box to the left then click "Delete"
Message 3 of 3
Thank you so much. All sorted. Dumb blonde moment. I thought deleting would do just that. I didn't realise that would reinstate it to safe senders list...Lesson learnt.
