Message 21 of 22
Re: Hybrid Connect, network switch, separate DHCP server
So you are running the LAN and the WAN through the same switch, interesting.
Message 22 of 22
As a switch only routes using MAC addresses, I suppose it makes no difference if both WAN and LAN are being switched. I have run two different IP subnets through the same switch.
