Message 1 of 4
Hybrid and Google Wifi
I don't use the wifi of my Smarthub but rather use Google Wifi, connected to the hub thru ethernet with 4 access points (mesh) in my home.
I'm thinking of upgrading to Hybrid but can you tell me, in the case where Hybrid kicks in, will the Hub still work with my Google access points? basically is the failover seamless, and the hub uses data from the Hybrid unit but still routes traffic via the external wifi points?
3 REPLIES 3
Message 2 of 4
Re: Hybrid and Google Wifi
Can anyone help?
I guess the question is basically the same as does any ethernet port on the hub work alongside the Hybrid
Message 3 of 4
The hybrid connects to the WAN side of the hub, it simply replaces the DSL signal. Nothing changes on your LAN network.
Message 4 of 4
thanks a lot!
