Message 1 of 5
Hybrid connect
I have just received a hybrid connect box  as part of BT halo 3 & have connected it as per instructions but there is no response,  no lights, nothing, WIFI is on but I don't have a smartphone to test it only my laptop, Any suggestions welcome please..
4 REPLIES 4
Message 2 of 5
Re: Hybrid connect
are you waiting for your broadband activation or has the hub lost internet connection?
Message 3 of 5
Re: Hybrid connect
No, I've had broadband for ages, I just received this Hybrid box as I just upgraded from Halo 2 to Halo 3..
Message 4 of 5
Re: Hybrid connect
it is designed to give you a 4g connection if you hub has no Internet connection
Message 5 of 5
Re: Hybrid connect
 Thanks for the explanation , Is there  supposed to be lights on even if my broadband is working  OK ?
