Message 91 of 124
Re: IP camera
I am guessing I will have to log into my NVR and edit each camera individually? I'm not sure what I'd done. When I first set it up. The cameras appeared automatically as soon as I plugged them into the box.
Message 92 of 124
Re: IP camera
SAPD allows you to find the IP cameras and NVR on your network. I don't know whether it's unique to Hikvision. I don't think it can be because I can see my bird box camera listed on there.
Message 93 of 124
Re: IP camera
I am not familiar with an NVR, I assume its a stand alone camera management, as opposed to a software solution like BI which I use for all my wired and wireless cameras.
Are they all wireless cameras?
Message 94 of 124
Re: IP camera
If I cannot find a device, I look in the DHCP table of my TP Link router, or use NMAP.
Message 95 of 124
Re: IP camera
Just back to the original discussion, how many bird boxes do you have?
We have one on an outside wall which has been claimed by a Robin. No camera inside though.
Message 96 of 124
Re: IP camera
This is the NVR box I use.
HiLook NVR-108MH-C/8P
This is one of the cameras.
HiLook By Hikvision IPC-D121H-M
Message 97 of 124
Re: IP camera
You need to edit out the links to Amazon, as you are not allowed to post them on this forum.
Message 98 of 124
Re: IP camera
Just one box. If you check The box in a minute you will probably see a little bird asleep in the box. They will probably start nesting at the end of March, into April. They done it for the last three years.
Message 99 of 124
Re: IP camera
Yes, my wife and I have been watching and recording the feed. It seems to want to destroy the inside of the box 😀
Message 100 of 124
Re: IP camera
Well, you have the link now. So at least you can watch. I just need to get it online so everybody else can. I'm a little bit annoyed with cam secure because I think they could have been a little bit more enthusiastic to help me.
That is a blue **bleep** with an identity crisis. It thinks it's a woodpecker
