Message 1 of 6
Intermittent Blank screen on all Channels
Hi I am getting a intermittent blank screen on all channels HD and non HD
I have tried rebooting router / tv box, changing tv picture quality and still every so often you hear a click and then screen freezes and then goes blank.
This started on sky channels and has moved to even bbc1 / itv even on none HD channels
I have fibre broadband at 150mbps so no speed problem does do it on demand / netflix etc
Thanks Nick
5 REPLIES 5
Message 2 of 6
Re: Intermittent Blank screen on all Channels
Typo error Is does NOT do it on Demand Netflix etc
Message 3 of 6
Hi @Nick_B
So if I understand correctly the issue is occuring on live channel viewing  using a BT TV  Youview box across both Freeview and BT Subcription channels on both HD and SD content.
Which BT TV Youview box model is it ?
If it is a recordabe box does the issue occur on recordings as well as live viewing ?
What TV model is it ?
How frequent is the issue occuring ?
How do you recover from the problem and get normal viewing back ?
I presume you are using an HDMI cable between BT TV Box  and TV , have you tried an alternative cable , tried different HDMI ports on the TV ?
Message 4 of 6
Hi Zulu thanks for the reply
Which BT TV Youview box model is it ? = DTRT4000
If it is a recordabe box does the issue occur on recordings as well as live viewing ? =not as far as i know
What TV model is it ? = LG 50UK6470
How frequent is the issue occuring ? all the time
How do you recover from the problem and get normal viewing back ? it normally sorts its self out after a minute or press menu sometimes even the menu page is blank
I presume you are using an HDMI cable between BT TV Box  and TV , have you tried an alternative cable , tried different HDMI ports on the TV ? = yes tried that
Message 5 of 6
Well after reading the same issue on other sites decided to use a TV adjustable Attenuator and after setting up no more issues 😀
Message 6 of 6
Thanks for letting us know you got this sorted @Nick_B . Appreciate you taking time to get back to us.
Cheers
David
