Message 1 of 6
Internet hangs, WiFi stable
Hi All,
Hope you're all well.
My Smart Hub router is causing a WiFi issue where the Internet hangs and stops working, even though the WiFi signal strength is on full bars.. I have to turn WiFi off and on again for the Internet to work.
Happens on multiple devices / phones.
I would be grateful if someone knows why this issue occurs. Tried changing channels, rebooting router, still hasn't fixed it.
5 REPLIES 5
Message 2 of 6
Re: Internet hangs, WiFi stable
Message 3 of 6
I am grateful for your response @Keith_Beddoe .
BT sent me a new Smart Hub so that's probably better than a factory reset and smart setup is already turned off.
Any other ideas?
Message 4 of 6
Did you try changing wireless mode in hub from default 1 to either 2 or 3?
Message 5 of 6
@imjolly that's literally the last thing I have tried. Takes a couple of days to see if the problem reoccurs. I'm hoping not.
What is the mode setting and why would it affect the issue I'm having?
Message 6 of 6
@imjolly same issue again this morning after changing mode from 1 to 2.
Would you have any other suggestions? Even BT engineers don't seem to know the issue.
Thanks in advance
