Message 1 of 1
Wired Access Points with BT Home Hub 5
I have BT Infinity going into BT Home Hub, but the wifi is not strong enough to get round my sprawling appartment and office combo.  I do have ethernet cables wired to each room so am looking for best Wired Access Points to create a good wifi network throughout.  Searching around the net, the best product seems to be the "Ubiquiti nanoHD" which is super fast and even provides for guest network...  So my question is can I simply plug these into my BT Home Hub via the ethernet cables?  And if so will the HomeHub still be the router or will it conflict with the Ubiquiti WAPs?... Or has anyone got a better solution to recommend?
