Message 11 of 17
Re: Late activation
Hi @RobbieMac
Thank you for post. I'm sorry, I was driving and wasn't able to answer on your call.
I'm working tomorrow, but I should be able take the call, the best time will be 1pm,as I'm on break then.
Piotr
Message 12 of 17
Re: Late activation
@PiotrP wrote:
Hi @RobbieMac
Piotr
No problem @PiotrP
I'll call as close to 1pm as possible tomorrow afternoon.
All the best,
Robbie
Message 13 of 17
Re: Late activation
@PiotrP  I hope the issue has been sorted. Just in case you are not aware, BT will have to pay you automatic compensation for the delay in activation. It is a £ 5.04 per each day of delay, from the initial date you have been told services would be activated, until the day before the activation actually occurred. The total value should be added as a credit to your BT account to offset your bill. Although, you also have the option to request the credit value to be refunded to your bank account.
Message 14 of 17
Re: Late activation
@SenseiEverything is going in good direction. Activation date is se on 8th so hopefully everything will be ok this time. Compensation will have to be manually because of all problems at the beginning.
Message 15 of 17
Re: Late activation
@PiotrP Once activation occurs (if on the 8th) please make sure you mention the automatic compensation and if you want ask for the credit on your account (once processed - within 15 days) to be refunded to your bank account. Good luck!
Message 16 of 17
Re: Late activation
Hi @PiotrP
Thank you for taking the time to chat with me again this morning.
I am really pleased that your services are up and running now.  Everything that we discussed on the call have been applied too.
As agreed, I'll go ahead and close this off from here.  If you need help or have any questions in future feel free to post back as you're more than welcome 😀
All the best,
Robbie
Message 17 of 17
Re: Late activation
@RobbieMacThank you again for you help and kindness. I can confirm that all ends well, and my broadband is up as promised. I'm happy customer now🙂
All the best
Piotr
