Message 1 of 7
MIS code not implemented
Has anyone had this error code. I’ve had the app on 5 different devices and worked fine, I’ve uninstalled and re installed several times to no avail,
6 REPLIES 6
Message 2 of 7
Re: MIS code not implemented
Hi @Bradbury1977,
Can you check the app market today to see if an update is now available to you?
Let me know how you get on please.
DanielS
Message 3 of 7
Hi, updated today and it’s still the same.
regards
Mike
Message 4 of 7
Hi @Bradbury1977 thanks for trying that. Would you confirm if this is the MyBT app or BT Wifi app?
I know you have it on multiple devices but would you confirm the model of one device you are using and getting this error and whether it is android or IOS and the version of the operating system on the device.
John
Message 5 of 7
Hi, I’m using it on a device I’ve used before and iPad Pro 2019, iPhone XS and iPad Air 2 2018, and to confirm it is the MyBt app.
regards
mike
Message 6 of 7
Hi @Bradbury1977 thanks for getting back to me. If you could check one of the devices for the version of IOS that is running it would help the app team to test.
You can check this via the Settings app. Navigate to Settings > General > About. You’ll see the version number to the right of the “Version” entry on the About page.
I've sent you a Private Message with details on how to contact the Mod team so we can help you get this issue with the app resolved.
cheers
John
Message 7 of 7
Hi it’s the mist upto date os 13.5
thanks
