Message 11 of 23
Re: Master Socket - Move options and Cost
do you have more than 1 extension socket in your home?
Message 12 of 23
3 total
Message 13 of 23
as there is only 1 pair of wires at extension connection in master then the other extensions must be daisy chained from each other.  are extensions in use or not?
Message 14 of 23
Nothing in them, except router now in one
Message 15 of 23
any other advice - seems that this has been a failed experiment if my speed has dropped as a result.  is this down to my internal wiring or do i need to do anything else ?
Message 16 of 23
Normally to create the data extension you would move  the cable for the extension from terminals 2&5 and connect it to the 2 terminal on the back of the faceplate.  You would then need to use a filter in the data extension socket
Message 17 of 23
thats what i have done, but as i say the speed dropped as a result 😞  i guess i should just revert it back, unless i go down the original route and have it properly moved.
thanks for the help, back to the garage it goes.
Couple of parting questions:-
Should i still be getting a dial tone on extensions if ive hooked up the data extension to the back of the faceplate?  (plugged in a test phone)
Do i need to reconnect anything at master if im moving it back (dont use phone / only mobile)
Message 18 of 23
An old video so you don't need all the tools but shows how to wire it up.
https://www.youtube.com/watch?v=Trk9OnZTIsE
Message 19 of 23
Before you do that, try disconnecting any wiring to further extensions not in use. I'm assuming that the extension you wish to use is directly connected to the master and not via one of the other extensions. I.e it is the first in the daisy chain after the master.
No
Message 20 of 23
I dont think it is tbh, but i could try disconnecting the others since i dont use anyway and i'll report back.
