Message 1 of 4
Master Sockets
I've ordered BT broadband to be used in my room and I don't have a master socket in my room but I don't know if it would be possible to have one installed into my room and if BT offers to install them or not?
3 REPLIES 3
Message 2 of 4
Re: Master Sockets
do you have an existing BT landline or are you new to BT?  what service are you getting Fibre to your home - FTTP  or fibre to the cabinet - FTTC
Message 3 of 4
Re: Master Sockets
I'm new to BT so I don't have any existing BT lines and I don't know how to check whether its FTTP or FTTC. The package I have bought is Fibre 1.
Message 4 of 4
Re: Master Sockets
then probably FTTC  fibre to cabinet and copper phone to your home
The openreach engineer will need to install a master socket if you do not have an existing openreach phone line whether active or not
