Message 1 of 3
Merging Multiple Forum Accounts
Hello.
Have multiple account, is it possible to merge them under one login?
tw: @Researc34044981
w: https://www.linkedin.com/in/ookwudili
wr: http://orcid.org/0000-0002-7186-8558
https://medium.com/@ookwudili_68379
https://www.mendeley.com/profiles/obi-o/
2 REPLIES 2
Message 2 of 3
Re: Merging Multiple Forum Accounts
You should only have one forum account so it should be possible to merge them or at least delete the extra ones you have set up.
I have notified the moderators of the forum. Once they have read this they may be able to help. They are very busy at present so it can take up to 24 hours for them to contact you. They will do this by posting on this thread.
Message 3 of 3
Hi @ookwudili
Thanks for your post.
As per the forum terms of use, you're only permitted to have one forum profile.  Therefore, we wouldn't be able to merge them.
Can you please send me a private message with the forum usernames and also confirm which profile you'd like to remain active moving forward?  I will remove the access for the other account.
Click into my profile and you'll see the option to message me on the top right hand corner.
Cheers,
Robbie
