Message 81 of 83
Re: Mitel Office IP Phone DHCP Discovery Issue
@meg_wrote:
Update: The new router didn’t work unfortunately 😞
At all or to resolve the issue?
Did you unplug and restart the phone?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 82 of 83
You should be able to get an Internet connection, provided you have configured it correctly as a PPPoE connection, and entered the correct login details. It should be quite simple.
Message 83 of 83
As shown here. That is assuming you are having a problem getting an Internet connection.
Your BT Business login goes in this next screen.
